> On 2013-09-13 11:15, AL13N wrote:
>>> On 2013-09-12 13:33, AL13N wrote:
>>>> This should be a patch for
>>>> A) allowing multiple main config files
>>>> i haven't compiled/run/tested this yet, but this is the kind of thin=
g
>>>> i
>>>> thought would be good.
>>>> can someone please tell me if i'm working in the right direction or
>>>> not?
>>> Sort of, and then again, no. It would be good if, as a first step, we
>>> read all main-config-parameters from read_main_config_file() (or some
>>> other function which just groks key/value pairs that gets fed by one
>>> or more invocations of read_main_config_file()).
>>> That way the patch wouldn't have to fiddle with object config reading=
>>> which won't work properly unless you also add multi-config support to
>>> read_object_config_files().
>> but, that's the way it's written now... we'd have to refactor the way
>> the
>> config files are read, and then the patch would be quite invasive,
>> wouldn't it?
>> did you see the 2nd patch? where i added multi-config support for
>> read_object_config_files? (or at least very basic, i didn't check if
>> these
>> functions reset some internal variables at the start of their call)
> Ah, no, I didn't.
>> what exactly are you thinking of doing?
> All the "initialize this" and "read_object_config_data()" only parse
> a few variables out of the main config file(s) and then set a few
> variables based on values found there. I would much prefer to have
> config variables read in a single place, all the variables properly
> set based on the latest parsed value (last in wins the race, basically)=
> and then calling the init functions while removing the config file
> argument to them completely.
yes, that does seem better, but that's quite some refactoring... i guess
if you insist, we'll have to do this one first...
combined with that, there's the added problem of config_file_dir where th=
e
dir of the main config file is used for whatever default directory.
i had to have a main config file and extra config files, if we get to
directories, the first main config will not be able to be used...
