[Nagios-devel] Nagios experimental repo
Ahoy.
I'll start working on the features I sent out RFC's for a couple of
weeks ago. The work will be stashed on op5's public git server so as
to avoid branching hell on SVN and potential user confusion from
admins running alpha-status code. Those interested in following the
progress can point their browsers to
http://git.op5.org/git/?p=nagios/nagios-exp.git
or clone from the repository at
git://git.op5.org/nagios/nagios-exp.git
and fetch or pull every once in a while. First out is the worker
process changes. Partly because they won't change the ABI or API in
an incompatible way, but mostly because they seem the most fun by
far. Module developers, and particularly module developers that use
a socket to communicate with something else, should like the
upcoming changes quite a lot (Hi Sven and Mathias).
In case it's not obvious, you shouldn't use the code from that repo
on production systems. I'll send out an email when there's enough new
stuff in there to make testing worthwhile.
OP5 AB www.op5.se
on peace.
