On 31 May 2003 at 23:41, Karl DeBisschop wrote:
> On Fri, 2003-05-30 at 15:08, Ethan Galstad wrote:
> > I was just about to release 1.1 on my day off, so this is good
> > timing. I forgot to apply the cmd CGI patch to the 1.x branch, but
> > will do so ASAP. FYI, the stable branch of CVS for 1.x is called
> > nagios-1-x-bugfixes.
> > I believe the Postgres timestamp patch (submitted by jbearce on Nov.
> > 6th) was already applied to 1.0, although there might have been a
> > later patch that I missed. Other than that, you got all the patches
> > since 1.0 (there weren't many).
> The spec file has been patched in CVS.
> I am getting an error in the build, however:
> perl -MExtUtils::Embed -e xsinit
> gcc -O3 -mcpu=pentium -I/usr/include -DHAVE_CONFIG_H -c perlxsi.c `perl
> -MExtUtils::Embed -e ccopts`
> gcc -O3 -mcpu=pentium -I/usr/include -DHAVE_CONFIG_H -c mini_epn.c `perl
> mini_epn.c: In function `main':
> mini_epn.c:116: `my_perl' undeclared (first use in this function)
> mini_epn.c:116: (Each undeclared identifier is reported only once
> mini_epn.c:116: for each function it appears in.)
> make: *** [mini_epn] Error 1
> error: Bad exit status from /tmp/rpm-tmp.53847 (%build)
> This is on RH 9. I'll look into it, but if anyone recognizes the
> problem, I'm not averse to hints.
Are you sure you have an up-to-date version of mini_epn.c? I can't
find any reference to "my_perl" in the current code.
> RE: postgresql, you did apply
> http://sourceforge.net/mailarchive/mess ... id=2450802
> for 7.2 -- the patch I added was
> http://sourceforge.net/mailarchive/foru ... um_id=1872
> for 7.3
> I have it in patch form. If you want me to apply if, say the word. I'll
> attached the patch as well.
I tracked down the patch yesterday and applied it to CVS, so we
should be good to go. Thanks!
Ethan Galstad,
Nagios Developer
Email: [email protected]
