Re: [Nagios-devel] Re: Nagios/CVS HEAD compilation issues on Solaris (nanosleep patch)
Thanks - will get this applied to CVS tonight.
On 22 Nov 2003 at 14:20, Joe Rhett wrote:
> gcc -g -O2 -I/opt/imagelib/include -DHAVE_CONFIG_H -DNSCORE -o nagios
> nagios.c broker.o nebmods.o checks.o config.o commands.o events.o
> flapping.o logging.o notifications.o sehandlers.o utils.o
> retention-base.o xretention-base.o comments-base.o xcomments-base.o
> objects-base.o xobjects-base.o statusdata-base.o xstatusdata-base.o
> perfdata-base.o xperfdata-base.o downtime-base.o xdowntime-base.o
> -L/opt/imagelib/lib -lm -lnsl -lsocket -lpthread -ldl Undefined
> first referenced
> symbol in file
> nanosleep events.o
> ld: fatal: Symbol referencing errors. No output written to nagios
> collect2: ld returned 1 exit status
> To get nanosleep on Solaris, so you have to link with -lrt.
> (it's also in -lposix4, but will be removed in future versions)
> This should be tested for by autoconf.
> I was prepared to provide an autoconf patch, but configure.ac was not
> included in the CVS sources. However, something like this is probably
> all that is needed.
> AC_SEARCH_LIBS(nanosleep, [rt], [posix4], [], [
> echo "nanosleep() required for timing operations."
> exit 1
> Joe Rhett Chief Geek
> [email protected] Isite Services,
> Inc.
> This SF.net email is sponsored by: SF.net Giveback Program.
> Does SourceForge.net help you be more productive? Does it
> help you create better code? SHARE THE LOVE, and help us help
> YOU! Click Here: http://sourceforge.net/donate/
> Nagios-devel mailing list
> [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
