I use Nagios core 3.2.3
I use check_snmp_ifstatus.pl, which needs to run every 30 seconds.
So, I did setup a service as bellow :
host_name sw-00-00
service_description BP Port 24
#check_command check_bw!24!1000!m!500!700
check_command check_bw!24!1000000000
use snmp-port-bw,srv-pnp
}Code: Select all
name snmp-port-bw; The 'name' of this service template
use generic-snmp
normal_check_interval 30s
retry_check_interval 15s
#max_check_attempts 2
# action_url /nagios-pnp/?host=$HOSTNAME$&srv=$SERVICEDESC$
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
}Code: Select all
name generic-snmp ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
failure_prediction_enabled 1 ; Failure prediction is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
notification_interval 0 ; Only send notifications on status change by default.
is_volatile 0
check_period 24x7
#normal_check_interval 1
#retry_check_interval 30s
max_check_attempts 4
notification_period 24x7
notification_options w,u,c,r
contact_groups admins
}The matter is when I check for the service execution (ps ax|grep check_snmp_ifstatus), I don"t see this service running every 30 seconds. What's wrong ?
Regards.
