On Sat, 2003-05-31 at 12:35, Ethan Galstad wrote:
> On 31 May 2003 at 23:41, Karl DeBisschop wrote:
> > On Fri, 2003-05-30 at 15:08, Ethan Galstad wrote:
> > > I was just about to release 1.1 on my day off, so this is good
> > > timing. I forgot to apply the cmd CGI patch to the 1.x branch, but
> > > will do so ASAP. FYI, the stable branch of CVS for 1.x is called
> > > nagios-1-x-bugfixes.
> > > I believe the Postgres timestamp patch (submitted by jbearce on Nov.
> > > 6th) was already applied to 1.0, although there might have been a
> > > later patch that I missed. Other than that, you got all the patches
> > > since 1.0 (there weren't many).
> > The spec file has been patched in CVS.
> > I am getting an error in the build, however:
> > perl -MExtUtils::Embed -e xsinit
> > gcc -O3 -mcpu=pentium -I/usr/include -DHAVE_CONFIG_H -c perlxsi.c `perl
> > -MExtUtils::Embed -e ccopts`
> > gcc -O3 -mcpu=pentium -I/usr/include -DHAVE_CONFIG_H -c mini_epn.c `perl
> > mini_epn.c: In function `main':
> > mini_epn.c:116: `my_perl' undeclared (first use in this function)
> > mini_epn.c:116: (Each undeclared identifier is reported only once
> > mini_epn.c:116: for each function it appears in.)
> > make: *** [mini_epn] Error 1
> > error: Bad exit status from /tmp/rpm-tmp.53847 (%build)
> > This is on RH 9. I'll look into it, but if anyone recognizes the
> > problem, I'm not averse to hints.
> Are you sure you have an up-to-date version of mini_epn.c? I can't
> find any reference to "my_perl" in the current code.
I have modifiied the spec to build mini-epn only when embedded perl is
specified. With this change, RH9 will build the standard RPMs. As far as
I am concerned, there should be no further issues preventing a 1.1
release.
Karl
