Re: [Nagios-devel] NDO increase nagios_servicechecks/output size
Already mentioned inside the TODO File :-)
1. Change fields of type VARCHAR(255) to BLOBs. VARCHAR fields were
easier for me to debug things as I was developing this addon, but
several text fields can be longer than 255 chars. Nagios 3.0
will allow multi-line plugin output, so this is especially important
for future compatability.
Cheers Gerd
Am Donnerstag, den 13.09.2007, 15:08 +0200 schrieb Michael Streb:
> correction:
> the same "problem" in:
> nagios_statehistory
> nagios_eventhandlers
> nagios_notifications
> nagios_servicestatus
> nagios_systemcommands
> nagios_hostchecks
> nagios_hoststatus
> Regards,
> Michael
> Am 13.09.2007 14:48 Uhr schrieb "Michael Streb" unter :
> > Hi Ethan,
> > Hi list,
> > recently went into problems with the "output" field in the
> > nagios_servicechecks table so i had a deeper look and it turned out that the
> > field size is set to "varchar(255)" only, i think this should be increased
> > to something like "varchar(4096)" to make use of the longer serviceoutput in
> > nagios3x.
> > I don`t know right now if 4k is the maximum serviceoutput in 3x.
> > Ethan it`s your turn. :)
> > Greetings,
> > Michael
Gerd Mueller NETWAYS GmbH
Senior Systems Engineer Deutschherrnstr. 47a
Fon. +49 911 92885-0 D-90429 Nuernberg
Fax. +49 911 92885-33
[email protected] http://www.netways.de
