On 09/17/2012 09:41 AM, Johannes Dagemark wrote:
> On 2012-09-14 18:45, Andreas Ericsson wrote:
>> For the (extremely) common "depend on a client version check" thing,
>> that would look something like this:
>> define service {
>> use some-suitable-template
>> host_name A
>> description NRPE Disk /
>> parents NRPE Version Check
> Can I do
> define service {
> host_name A
> description PING
> parents switchA;PING
Yes.
> or do I need a service dependency for that?
No, but you could use one if you want. However, the ping scenario is
a bit dubious since services implicitly depend on their host being up
and with switches it's natural to use ping to do that check.
OP5 AB www.op5.se
on peace.
