[Nagios-devel] [PATCH 1/2] runcmd: Fix quoting issues when running
The important part of this patch is one line that makes sure that if
we're in single quoted mode, we should ignore '\' as an escape
character.
Without this, foo\\bar was interprented exactly the same as 'foo\\bar'.
With it, the former is executed as one backslash, the latter as two.
There's is also a new test-runcmd, with a small set of test cases for
the command quoter.
Signed-off-by: Robin Sonefors
lib/Makefile.in | 4 ++--
lib/runcmd.c | 3 ++-
lib/runcmd.h | 2 ++
lib/test-runcmd.c | 57 +++++++++++++++++++++++++++++++++++++++++++++++++++++++
4 files changed, 63 insertions(+), 3 deletions(-)
create mode 100644 lib/test-runcmd.c
diff --git a/lib/Makefile.in b/lib/Makefile.in
index f853ce7..fdf3962 100644
--- a/lib/Makefile.in
+++ b/lib/Makefile.in
@@ -8,8 +8,8 @@ LIBNAME = libnagios.a
all: $(LIBNAME)
SNPRINTF_O=@SNPRINTF_O@
-TESTED_SRC_C := squeue.c kvvec.c iocache.c iobroker.c bitmap.c dkhash.c
-SRC_C := $(TESTED_SRC_C) pqueue.c runcmd.c worker.c skiplist.c nsock.c
+TESTED_SRC_C := squeue.c kvvec.c iocache.c iobroker.c bitmap.c dkhash.c runcmd.c
+SRC_C := $(TESTED_SRC_C) pqueue.c worker.c skiplist.c nsock.c
SRC_C += nspath.c
SRC_O := $(patsubst %.c,%.o,$(SRC_C)) $(SNPRINTF_O)
TESTS := $(patsubst %.c,test-%,$(TESTED_SRC_C))
diff --git a/lib/runcmd.c b/lib/runcmd.c
index 8664fcd..95bd4c5 100644
--- a/lib/runcmd.c
+++ b/lib/runcmd.c
@@ -151,7 +151,8 @@ int runcmd_cmd2strv(const char *str, int *out_argc, char **out_argv)
break;
case '\\':
- i++;
+ if (!have_state(STATE_INSQ))
+ i++;
break;
case '\'':
diff --git a/lib/runcmd.h b/lib/runcmd.h
index 2217dc4..63e94d2 100644
--- a/lib/runcmd.h
+++ b/lib/runcmd.h
@@ -1,6 +1,8 @@
#ifndef INCLUDE_runcmd_h__
#define INCLUDE_runcmd_h__
+#include
* @file runcmd.h
* @brief runcmd library function declarations
diff --git a/lib/test-runcmd.c b/lib/test-runcmd.c
new file mode 100644
index 0000000..8bbff42
--- /dev/null
+++ b/lib/test-runcmd.c
@@ -0,0 +1,57 @@
+#include "runcmd.c"
+#include "t-utils.h"
+#include
+#define BUF_SIZE 1024
+struct cases {
+ char *input;
+ char *output;
+struct cases cases[] = {
+ {"te\\st1", "test1"},
+ {"te\\\\st2", "te\\st2"},
+ {"te\\\\\\st3", "te\\st3"},
+ {"te\\\\\\\\st4", "te\\\\st4"},
+ {"\"te\\st5\"", "test5"},
+ {"\"te\\\\st6\"", "te\\st6"},
+ {"\"te\\\\\\st7\"", "te\\st7"},
+ {"\"te\\\\\\\\st8\"", "te\\\\st8"},
+ {"'te\\st9'", "te\\st9"},
+ {"'te\\\\st10'", "te\\\\st10"},
+ {"'te\\\\\\st11'", "te\\\\\\st11"},
+ {"'te\\\\\\\\st12'", "te\\\\\\\\st12"},
+ {"\\'te\\\\st13", "'te\\st13"},
+ {"'test14\"'", "test14\""},
+ {NULL},
+int main(int argc, char **argv)
+ runcmd_init();
+ t_set_colors(0);
+ t_start("runcmd test");
+ int i;
+ char *out = calloc(1, BUF_SIZE);
+ for (i = 0; cases.input != NULL; i++) {
+ memset(out, 0, BUF_SIZE);
+ int pfd[2] = {-1, -1}, pfderr[2] = {-1, -1};
+ int fd;
+ char *cmd;
+ asprintf(&cmd, "/bin/echo -n %s", cases.input);
+ fd = runcmd_open(cmd, pfd, pfderr, NULL);
+ read(pfd[0], out, BUF_SIZE);
+ ok_str(cases.output, out, "Echoing a command should give expected output");
+ close(pfd[0]);
+ close(pfderr[0]);
+ close(fd);
+ t_end();
+ return 0;
1.7.11.7
