SCHAER Frederic wrote:
> Hi list,
> I just tried to buid RPM packages for nagios 3.0b5 on a x86_64 redhat
> node and… compilation failed because :
> Checking for unpackaged file(s): /usr/lib/rpm/check-files
> /var/tmp/nagios-buildroot
> error: Installed (but unpackaged) file(s) found:
> /usr/lib/nagios/cgi/avail.cgi
> /usr/lib/nagios/cgi/cmd.cgi
> /usr/lib/nagios/cgi/config.cgi
> /usr/lib/nagios/cgi/extinfo.cgi
> /usr/lib/nagios/cgi/histogram.cgi
> /usr/lib/nagios/cgi/history.cgi
> /usr/lib/nagios/cgi/notifications.cgi
> /usr/lib/nagios/cgi/outages.cgi
> /usr/lib/nagios/cgi/showlog.cgi
> /usr/lib/nagios/cgi/status.cgi
> /usr/lib/nagios/cgi/statusmap.cgi
> /usr/lib/nagios/cgi/statuswml.cgi
> /usr/lib/nagios/cgi/statuswrl.cgi
> /usr/lib/nagios/cgi/summary.cgi
> /usr/lib/nagios/cgi/tac.cgi
> /usr/lib/nagios/cgi/trends.cgi
> When I look in the rpm buildroot, I see this :
> [nagios-buildroot]# ll usr/lib/nagios/cgi/
> total 3292
> -rwxrwxr-x 1 root root 238544 Oct 31 11:42 avail.cgi
> -rwxrwxr-x 1 root root 228400 Oct 31 11:42 cmd.cgi
> -rwxrwxr-x 1 root root 194160 Oct 31 11:42 config.cgi
> -rwxrwxr-x 1 root root 244208 Oct 31 11:42 extinfo.cgi
> -rwxrwxr-x 1 root root 198896 Oct 31 11:42 histogram.cgi
> -rwxrwxr-x 1 root root 179536 Oct 31 11:42 history.cgi
> -rwxrwxr-x 1 root root 177040 Oct 31 11:42 notifications.cgi
> -rwxrwxr-x 1 root root 172912 Oct 31 11:42 outages.cgi
> -rwxrwxr-x 1 root root 177296 Oct 31 11:42 showlog.cgi
> -rwxrwxr-x 1 root root 235792 Oct 31 11:42 status.cgi
> -rwxrwxr-x 1 root root 197840 Oct 31 11:42 statusmap.cgi
> -rwxrwxr-x 1 root root 189904 Oct 31 11:42 statuswml.cgi
> -rwxrwxr-x 1 root root 177104 Oct 31 11:42 statuswrl.cgi
> -rwxrwxr-x 1 root root 197584 Oct 31 11:42 summary.cgi
> -rwxrwxr-x 1 root root 189392 Oct 31 11:42 tac.cgi
> -rwxrwxr-x 1 root root 203696 Oct 31 11:42 trends.cgi
> [nagios-buildroot]# ll usr/lib64/nagios/cgi/
> total 12
> -rwxrwxr-x 1 root root 5335 Oct 31 11:42 traceroute.cgi
> It looks like the non-64 libs are not packaged.
> When I change in the spec file references to ${_libdir} and write
> instead ${_prefix}/lib (i.e : replace all occurrences of libdir with
> “prefix / lib” as can be found already in the specfile) , RPM creation
> succeeds…
> Maybe someone could correct this in the sources ?
> Best regards,
> Frederic Schaer
Patch will be in CVS shortly. Thanks.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
