Hi all,
About a month ago I posted a similar mail. I've had the same problem,
only that the cause slightly differed. Here, it happened when I turned
logging of external commands on/off from the web interface- I believe.
Not 100% sure, I'd have to look it up in the mail archive or try to
replicate.
Unfortunately I've never gotten a reply to my inquiry, so I left living
with it.
The version I used then was nagios 1.0b6 on a suse linux 7.3 system.
Maybe this problem can get cleared up this time.I hope...
Greetings
Daniel
-----Original Message-----
[mailto:[email protected]] On Behalf Of Russell
Scibetti
Sent: Tuesday, November 12, 2002 6:35 PM
To: [email protected];
[email protected]
Subject: [Nagios-users] BIG problem: Nagios Processes and OCSP
I am having a very unusual problem with Nagios. I am running a few
instances of Nagios 1.0b6 on a Linux RedHat7.2 box, one of which has
about 700+ services, most of which are polled every 5 minutes.
After a very short amount of time, there are hundred on nagios processes
hanging around for this instance. I know that you are supposed to see
some nagios processes because of the plugin forking, but this is well
beyond what there should be. It's around the 200-300 range. The box
starts dipping into swap and nagios doesn't get all of the plugins done
in time, even though the load on the box is still minimal. Soon the
plugins are almost 1/2 hour behind.
Now here is the confusing part. I turned on obsess_over_services for
the instance and created a command that just logs the results of every
check to a file. I wanted to try and see in more detail what was
happening. I stopped and started the instance, and now the problem is
gone. All the checks are completed at the right time, there is plenty
of free memory (no swapping) and the process count stays very low.
Is this some form of bug? What is special with the obsess_over_services
setting that gets rid of the problem? If anyone has any idea what could
be going on, please respond. Thanks.
-Russell Scibetti
Russell Scibetti
Quadrix Solutions, Inc.
http://www.quadrix.com
(732) 235-2335, ext. 7038
This sf.net email is sponsored by:
To learn the basics of securing your web site with SSL,
click here to get a FREE TRIAL of a Thawte Server Certificate:
http://www.gothawte.com/rd522.html
_______________________________________________
Nagios-users mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-users
