Re: [Nagios-devel] [PATCH] check_smtp.c - float warn/crit thresholds
Hash: SHA1
Just a note: If you would do more patchworking on the plugins you might
go over to the nagiosplug-devel list.
https://lists.sourceforge.net/lists/lis ... plug-devel
Ignacio Goyret schrieb:
> Hi all,
> The attached patched allows check_smtp.c to accept double (floating
> point) values for warning and critical thresholds. Previously, it
> only accepted integers.
> Note that the help message (check_smtp -h) indicated that these
> parameters were supposed to be DOUBLE so this change makes it
> consistent.
> Cheers,
> -Ignacio
> PS: The attached patch is svn-based. I found the issue on
> nagios-plugins-1.4.13.
> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
> Build the coolest Linux based applications with Moblin SDK & win great prizes
> Grand prize is a trip for two to an Open Source event anywhere in the world
> http://moblin-contest.org/redirect.php? ... =100&url=/
> Nagios-devel mailing list
> [email protected]
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (Darwin)
iEYEARECAAYFAkkjGCwACgkQlI0PwfxLQjneoQCfZj/WVhoQpV8IoAIEAksW3vMr
G5EAnRiF6TrYGwve410bbc0FmtJ902oN
=ZTGl
-----END PGP SIGNATURE-----
