Re: [Nagios-devel] Nagios3-cvs: Possible bug in additive
Mathieu Gagn=E9 schrieb:
> Hi,
>=20
> Matthias Eble writes:
>=20
>> with the latests cvs version this doesn't seem work.
>> I looked at the source and the problem is that=20
>> xodtemplate_clean_additive_strings() is called before=20
>> xod_template_inherit_object_properties(). But the latter tries to do=20
>> some additive inheritance, too. Unfortunately the + signs are gone the=
n.
>> My suggest would be to move xod_template_inherit_object_properties()=20
>> before xodtemplate_clean_additive_strings() so that the inheritance wo=
rk=20
>> is done before the duplication tasks.
>=20
> I'm facing the same issue on my side too.
> Any idea?
This is more an obvious than a possible bug if you ask me.
I think I picked the wrong subject text.
matthias
