On Thu, 21 Mar 2002, Alex Kuehne wrote:
> > Nagios currently uses the embedded perl interpreter to execute perl
> > plugins without the additional overhead of starting the interpreter
> > everytime.
> Okay, is it automatically done when you compile Nagios with embedded
> perl support?
yes
> > The only way you can use it currently is to write perl plugins.
> This it what I assumed ...
> > When you say extension - what type of extension are you envisioning?
> > On the cgi/web interface? or on the scheduling/monitoring side?
> My Netsaint/Nagios host becomes the local loghost, where every
> syslogable machine will log to, and that's a lot. I use MySQL for
> storing all the syslog stuff, and now I use Nagios for analysing
> what's going on. The idea is to have a plugin for cross-checking the
> database for words like "refused" "error" and all the bad things which
> happens every day, and returning Warning or Critical when it is found.
> For this I need a plugin.
