--------------060908080003040003010704
Content-Type: text/plain; charset=ISO-8859-15
There was a typo in my last patch according to the try to printout the
actual temp_path value with snprintf...
Please take this patch instead!
Regards
Hendrik
Content-Type: text/x-patch;
name="config.c.-temp_path_checking-v2.patch"
Content-Disposition: inline; filename="config.c.-temp_path_checking-v2.patch"
--- ./nagios3-clean/base/config.c 2007-03-25 10:06:23.000000000 +0200
+++ ./nagios3/base/config.c 2007-03-25 11:18:09.000000000 +0200
@@ -404,6 +404,20 @@
break;
+ if(opendir((char *)value)==NULL){
+ strcpy(error_message,"Temp path is not valid");
+ error=TRUE;
+ break;
+ // Maybe we should close the dirhandle but what to close
+ // without a normal DIR handle?
+ // With a temp DIR Handle there would be a new only temp variable...
+ // closedir(SOMESTUPID_HANDLE);
+ // Maybe we should check if the DIR Handle is writeable by us?
+ // AFAIK we need ...
my_free((void **)&temp_path);
if((temp_path=(char *)strdup(value))){
strip(temp_path);
--------------060908080003040003010704--
