Re: [Nagios-devel] Leading space in continuation lines
Holger Weiss wrote:
> * Gerhard Lausser [2009-05-02 13:49]:
>> I attached a patch for base/utils.c(mmap_fgets_multiline) (v3.10) which cuts
>> off leading white space from continuation lines.
> Of course, this breaks configurations which do stuff like
> command_line $USER1$/check_foo one\
> two
> and expect to get this parsed with white space between "one" and "two".
> However, this incompatibility is probably negligible, and I guess most
> users would prefer if leading white space was stripped from continuation
> lines.
> So, I'd appreciate if the patch was committed. I've attached a version
> of the diff which updates cgi/cgiutils.c:mmap_fgets_multiline(), too,
> and which simplifies the code a bit.
> Holger
Thanks - patch is in CVS.
- Ethan Galstad
