Bernd Adamowicz wrote:
> (Hope I didn't cause too much confusion since I already posted this
> message once bevore beeing a member of this list.)
> Hi All,
> I'm facing the problem, that the pre flight check from nagios causes
> a segmentation fault, if the 'member' variable of a servicegroup
> contains a '*' wildcard. I have just compiled the latest CVS tarball
> because there have been some similiar bugs reported, but it didn't
> fix my problem.
[snip]
Thanks for the report. I believe I have located and fixed the bug. A
patch will be committed to CVS shortly.
> Maybe this will give someone of you a hint, what might have happened.
> (I was a little bit confused about the last modified date of 05-31-2006,
> but I'm shure I got the latest tarball.)
The date only gets updates when I make a release, but the tarballs
should always be current within the last 4 hours.
> Maybe someone has help. Thanks in advance.
> - Bernd Adamowicz (Bernd)
Ethan Galstad,
Nagios Developer
Email: [email protected]
