Re: [Nagios-devel] memory leak in Nagios 2.x utils.c
eponymous alias wrote:
> The following code in Nagios 2.10 utils.c contains a memory leak:
> 4885
> if(service_result_buffer.items==check_result_buffer_slots){
> 4886
> 4887 /* record overflow */
> 4888 service_result_buffer.overflow++;
> 4889
> 4890 /* update tail pointer */
> 4891
> service_result_buffer.tail=(service_result_buffer.tail + 1) %
> check_result_buffer_slots;
> 4892 }
> One needs the following lines between the overflow increment and the
> tail increment:
> /* We're about to discard the oldest result, to make room for the newest.
> Make sure we don't create a memory leak in doing so. */
> free (((service_message
> **)service_result_buffer.buffer)[service_result_buffer.tail]);
> Even if this code path is thought never to execute, the fix should still
> be put in to guide developers who may need to modify the code base.
Thanks for the note. I'll get this in CVS shortly...
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
