Please share away - more the better.
-sg
On Fri, 15 Nov 2002, Mark Gillett wrote:
> Hi Ethan et al,
> We have developed a Servlet gateway to Nagios MySQL which might be
> useful to some people. Perhaps more useful might be the XML definitions
> that we have worked up and the other components of the data structure
> etc.
> If anyone is interested, am happy to share the XML definitions and the
> Servlet code if that is of use !
> Regards,
> Mark Gillett
> IXIF Limited, Commercial Support for NMS
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Ethan
> Galstad
> Sent: 14 November 2002 03:39
> To: [email protected]
> Cc: [email protected]
> Subject: [Nagios-devel] XML Output
> It has been mentioned by several people in the past that it would be
> helpful if there was a way of getting status information in XML
> format. NTray is one program that would benefit from this.
> The easiest solution at the moment would be to write a CGI that does
> this. However, I know very little about XML at the moment, so I need
> assistance from people in the know. Specifically, what should the
> output look like to make it easy to interpret?
> There are 3 types of entities that have status data:
> - Process status (1 entry)
> - Host status (Multiple entries)
> - Service status (Multiple entries)
> I suppose it would be nice to be able to get access to comment and
> downtime data in XML format as well, although that is less of a
> priority that status data.
> Comments? Suggestions?
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> This sf.net email is sponsored by: Are you worried about
> your web server security? Click here for a FREE Thawte
> Apache SSL Guide and answer your Apache SSL security
> needs: http://www.gothawte.com/rd523.html
> Nagios-devel mailing list
> [email protected]
> This sf.net email is sponsored by: To learn the basics of securing
> your web site with SSL, click here to get a FREE TRIAL of a Thawte
> Server Certificate: http://www.gothawte.com/rd524.html
> [email protected]
