Hmmm,
This may actually be an issue of priority ? I haven't tested that =20
before when doing this.
Maybe moving your .cfg files that are in customers down a level to =20
common may fix the issue. It may be trying to fully vet the file =20
before recursing into the sub dirs.
Like I say I haven't seen that before but I haven't tested it either. =20
You could also do a second cfg_dir line that points to your common =20
service group and other high level files after your customer cfg_dir =20
directive.
Try those items and see if it changes the results any.
Derrick
Quoting Jo Rhett :
> On May 3, 2008, at 2:20 PM, Tom Throckmorton wrote:
>> Jo, could you cut and paste your relevant configuration bits for
>> enabling the cfg_dir / cfg_file directives?
> Sure. The first part of bone stock:
> # You can split other types of object definitions across several
> # config files if you wish (as done here), or keep them all in a
> # single config file.
> cfg_file=3D/d/nagios/etc/contactgroups.cfg
> cfg_file=3D/d/nagios/etc/contacts.cfg
> cfg_file=3D/d/nagios/etc/dependencies.cfg
> cfg_file=3D/d/nagios/etc/escalations.cfg
> cfg_file=3D/d/nagios/etc/hostgroups.cfg
> cfg_file=3D/d/nagios/etc/hosts.cfg
> cfg_file=3D/d/nagios/etc/servicegroups.cfg
> cfg_file=3D/d/nagios/etc/service-template.cfg
> cfg_file=3D/d/nagios/etc/services.cfg
> cfg_file=3D/d/nagios/etc/timeperiods.cfg
> There there is the custom part. The first line is commented out
> because it doesn't work. If I use this and comment out the later
> lines then none of the configuration files in these directories are
> parsed.
> # You can also tell Nagios to process all config files (with a .cfg
> # extension) in a particular directory by using the cfg_dir
> # directive as shown below:
> #cfg_dir=3D/d/nagios/etc/customers
> cfg_dir=3D/d/nagios/etc/customers/common
> cfg_dir=3D/d/nagios/etc/customers/9617
> cfg_dir=3D/d/nagios/etc/customers/9652
> cfg_dir=3D/d/nagios/etc/customers/9669
> cfg_dir=3D/d/nagios/etc/customers/9677
> cfg_dir=3D/d/nagios/etc/customers/9691
> cfg_dir=3D/d/nagios/etc/customers/9696
> cfg_dir=3D/d/nagios/etc/customers/9698
> cfg_dir=3D/d/nagios/etc/customers/9730
> cfg_dir=3D/d/nagios/etc/customers/9736
> cfg_dir=3D/d/nagios/etc/customers/9743
> If I uncomment the first line and comment out the later lines, I get
> the following:
> Performing sanity check of nagios configuration: FAILED
> Nagios 2.9
> Copyright (c) 1999-2007 Ethan Galstad (http://www.nagios.org)
> Last Modified: 04-10-2007
> License: GPL
> Reading configuration data...
> Error: Servicegroup has no members (config file '/d/nagios/etc/
> servicegroups.cfg', starting on line 6)
> This is a hint, because every service defined in these subdirectories
> is a member of that group. If I manually add a static service to
> that group, the error goes away but none of the hosts or services
> defined in those subdirectories appear in the configuration.
> Jo Rhett
> Net Consonance : consonant endings by net philanthropy, open source
> and other randomness
> This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
> Don't miss this year's exciting event. There's still time to save $100.
> Use priority code J8TL2D2.
> http://ad.doubleclick.net/clk;198757673 ... n.com/jav=
aone
> Nagios-devel mailing list
> [email protected]
