not the one notification prior to the recovery. It leaves those contacts
wondering if the problem was ever fixed.
Patrik Båt wrote:
> Why just send a recovery to someone who hasnt been informed of
> problem?
> On Thu, 2011-05-26 at 09:43 -0400, Paul M. Dubuc wrote:
>> I should have mentioned that whether this works depends on who the default,
>> non-escalated, contacts are for the host or service. In your case, since you
>> have last_notification set to 3, those contacts in your escalation will not
>> get a recovery notification that is numbered 5 or greater unless they also
>> happen to be the default contact for the host or service, which will get the
>> problem notification number 4 and all non-escalated notifications. If you
>> escalate a notification to a contact that is not assigned as a regular contact
>> for the host or service, those contacts don't get the recovery notification
>> (unless they also got the previous problem notification) even if you set up a
>> separate escalation for the recovery notification that specifies all previous
>> contacts.
