Re: [Nagios-devel] RFC: Host/Service Display Name
On 28 Feb 2006 at 12:16, jeff vier wrote:
> On Tue, 2006-02-28 at 11:59 -0600, Ethan Galstad wrote:
> > A common request in the past has been to add a new field to host and
> > service definitions that overrides the host_name/service_description
> > fields for display purposes in the web interface.
> > I am considering adding a 'display_name' (or similiarly named)
> > variable to host and service definitions to allow for this in Nagios
> > 3.x. This would also allow you to change the "name" of the
> > host/service that is viewable for customers/staff, while leaving the
> > underlying host_name/service_description the same for reporting
> > purposes.
> > Of course, corresponding $HOSTDISPLAYNAME$ and $SERVICEDISPLAYNAME$
> > macros will be added as well, to allow you to use the new names in
> > notification scripts, etc.
> > What are the general thoughts on this? Is there a better name than
> > 'display name' that should be used?
> 'Display Name' seems appropriate.
> I would prefer it be an optional tag (then, defaulting to the
> host_name if missing).
Yep, that's how it will work. If its missing it will default to
either host_name or service_description, whichever is appropriate for
the object type.
> On a somewhat related note:
> Any chance "Alias" can be renamed to "Description" (or "Desc")?
> For me, at least, getting Infrastructure to submit enough information
> to make a valid host entry is a hassle, as the "Alias" concept
> consistently eludes them.
I suppose it could be. Although its probably fun hassling the
infrastructure folks every once in a while to make sure they do
things right.
Ethan Galstad,
Nagios Developer
Email: [email protected]
