> ----- Original Message -----
>>> On 06/22/2012 08:57 PM, Ricardo Maraschini wrote:
>>>> hello,
>>>> i've removed two unused variables on found_macro_x() function.
>>>> Compiler errors:
>>>> ../common/macros.c: In function ‘process_macros_r’:
>>>> ../common/macros.c:133:6: warning: variable ‘found_macro_x’ set
>>>> but
>>>> not used [-Wunused-but-set-variable]
>>>> ../common/macros.c:128:6: warning: variable ‘x’ set but not used
>>>> OK? Comments?
>>> Test this with macro resolution debugging turned on. I just
>>> reverted a patch that did this change (and a bunch of other
>>> -Wunused-but-set-variable), and removing the unused ones
>>> actually broke macro resolution for the core.
>> Just for curiosity, the patch you've reverted had the same logic as
>> mine regarding strcmp()?
> Oh, now I see. I've made a diff between revisions 1853 and 1951 for common/macros.c and it clearly pointed me to a bug. That patch(applied to create revision 1951) is different of mine, regarding strcmp() use. Really, that patch is supposed to explode everything, you gonna see it if you look closely
> BTW, I've tested the patch i've sent to you and i had no problems regarding macro resolutions so far.
> [1340638282.241842] [2048.1] [pid=20560] **** BEGIN MACRO PROCESSING ***********
> [1340638282.241848] [2048.1] [pid=20560] Processing: '$USER1$/check_ssh -t 60 -p 54978 $HOSTADDRESS$'
> [1340638282.241910] [2048.1] [pid=20560] Done. Final output: '/usr/local/opmon/libexec/check_ssh -t 60 -p 54978 192.168.8.1'
> [1340638282.251285] [2048.1] [pid=20560] **** BEGIN MACRO PROCESSING ***********
> [1340638282.269438] [2048.1] [pid=20560] Processing: '$USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -t 60 -u -c $ARG1$ -a $ARG2$'
> [1340638282.269463] [2048.1] [pid=20560] Done. Final output: '/usr/local/opmon/libexec/check_nrpe -H 127.0.0.1 -p 5666 -t 60 -u -c otrs_tickets_entrada_user -a 0 0 3'
> [1340638282.277821] [2048.1] [pid=20560] **** BEGIN MACRO PROCESSING ***********
Excellent. I didn't have time to track that down earlier, so thanks
for doing it properly
I'll apply this (and the other ones squelching -Wset-but-unused warnings)
right away.
OP5 AB www.op5.se
on peace.
