Luiz Angelo Daros de Luca wrote:
> Hello,
> Nagios statusmap.cgi crashed when an unicode "ç" is present in the
> alias host name.
> *** buffer overflow detected ***: /usr/lib/nagios/cgi/statusmap.cgi terminated
> ======= Backtrace: =========
> /lib64/libc.so.6(__chk_fail+0x2c)[0x2aba4a7bd9ac]
> /lib64/libc.so.6[0x2aba4a7bcee9]
> /lib64/libc.so.6(_IO_default_xsputn+0x8e)[0x2aba4a753a7e]
> /lib64/libc.so.6(_IO_vfprintf+0x76e)[0x2aba4a7297fe]
> /lib64/libc.so.6(__vsprintf_chk+0x9d)[0x2aba4a7bcf8d]
> /lib64/libc.so.6(__sprintf_chk+0x80)[0x2aba4a7bced0]
> /usr/lib/nagios/cgi/statusmap.cgi[0x40b6f2]
> /usr/lib/nagios/cgi/statusmap.cgi[0x404f28]
> /usr/lib/nagios/cgi/statusmap.cgi[0x405932]
> This is gdb bt:
> #0 0x00002aba4a717b45 in raise () from /lib64/libc.so.6
> #1 0x00002aba4a7190e0 in abort () from /lib64/libc.so.6
> #2 0x00002aba4a74ffbb in ?? () from /lib64/libc.so.6
> #3 0x00002aba4a7bd9ac in __chk_fail () from /lib64/libc.so.6
> #4 0x00002aba4a7bcee9 in ?? () from /lib64/libc.so.6
> #5 0x00002aba4a753a7e in _IO_default_xsputn () from /lib64/libc.so.6
> #6 0x00002aba4a7297fe in vfprintf () from /lib64/libc.so.6
> #7 0x00002aba4a7bcf8d in __vsprintf_chk () from /lib64/libc.so.6
> #8 0x00002aba4a7bced0 in __sprintf_chk () from /lib64/libc.so.6
> #9 0x000000000040b6f2 in html_encode (
> input=0x689970 "Cartorio de BIGUAA�\207U", escape_newlines=1)
> at cgiutils.c:1497
> #10 0x0000000000404f28 in write_host_popup_text (hst=0x689790)
> at statusmap.c:1947
> #11 0x0000000000405932 in draw_hosts () at statusmap.c:1817
> #12 0x00000000004075a2 in display_map () at statusmap.c:824
> #13 0x0000000000407f3b in main (argc=,
> argv=) at statusmap.c:291
> #14 0x00002aba4a704b54 in __libc_start_main () from /lib64/libc.so.6
> #15 0x0000000000403609 in _start ()
Can you try the latest CVS snapshot (or CVS tarball) and see if the
problem is resolved? I increased the buffer length in case the int
value exceeds 255. Both the 2.x and HEAD (3.x) branches have been
updated with a potential fix.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
