Re: [Nagios-devel] RE: SNMP community in host configuration
How about adding some form of prefix to settings like:
userargs MYOWNKEY "This is a value"
That gets translated into: $MYOWNKEY$ when a command is executed?
That would allow people that have a need for user settings to use them =
and still not fill up the namespace. I know this might be useful for me =
as I have certain keys that are used changing based on "host groups" =
(read templates). For instance snmp community strings (and for that =
matter authorization tokens). Then I could derive all hosts using a =
certain snmp community from the same template? Also along this line =
something I have been wanting is "multiple inheritance" (don't laugh :). =
This would allow me to cross inherit settings from various classes.
To make an example of what I mean:
A server have different aspects:
1, contact settings (all our notes servers are "owned" by the same =
support group).
2, check frequency (test/verification systems need to be check less then =
ones that are serving users).
This is two aspects that could be inherited but are distinct (as in not =
the same) as we have notes-servers that are test and ones that are =
serving users. We also have the same aspects on other server groups.
Now this might be possible already (haven't tired, I just assumed that =
it couldn't be done)
If it sounds like a reasonable thing to do I could look into =
implementing it for nagios 2.0 but if it just me being deluded I can =
also manage this in my config files :)
// Michael Medin
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andreas =
Ericsson
Sent: den 11 januari 2005 16:33
To: Patrick Proy
Cc: 'nagios-devel'
Subject: Re: [Nagios-devel] RE: SNMP community in host configuration
Patrick Proy wrote:
> Hi,
>=20
> Did anybody test the patch ?=20
>=20
Like I told you before you went along hacking up this patch, it=20
addresses a very limited usergroup. I believe most networks have at the=20
most two or three snmp communities/username-password-pairs.
>=20
> Patrick
>=20
>=20
>>Envoy=E9 : mardi 21 d=E9cembre 2004 16:04
>>=C0 : 'nagios-devel'
>>Objet : [Nagios-devel] RE: SNMP community in host configuration
>>Hi,
>>I updated my patch. Works with today's CVS : "patch -p0 >patch_nag_snmp_2004.12.21.patch" :
>>- added "snmp_community" in host/template definition,=20
>>accessed by $SNMPCOMMUNITY$ macro.
>>- Changed the "hostuser" macro in "hostmacro" :=20
>> - in host/template definition : "hostmacro SomeData"
>> - In services : "$HOSTMACRO$"
>>- In nagios.cfg, the option is now named "host_snmp_login",=20
>>same syntax.=20
>>As usual, feedbacks are welcome !
>>Patrick
>>nagios AT proy.org
>>=20
>>>How to patch :=20
>>> - it work with the CVS version of 19 Dec 2004
>>> - in the "nagios-cvs" directory : "patch -p0 >
>>patch_nag_snmp.patch"
>>>Note : only works with template based config files.
>>>I tested it on Linux only for now, but as nothing is platform=20
>>>specific, it should be OK.
>>>Here are the modified files (if a new CVS version is out) :=20
>>>- common/objects.c base/config.c base/nagios.c base/utils.c=20
>>>include/common.h include/objects.h include/nagios.h.in=20
>>>xdata/xodtemplate.c xdata/xodtemplate.h
>>>What it does :
>>>1) SNMP for each host
>>>You can put snmp information in three ways :=20
>>>- In the host definition :
>>> snmp_version # stores snmp version
>>> snmp_login # stores snmp login (for v3)
>>> snmp_pass # stores snmp password for v3 or=20
>>>community for
>>>v1
>>>None of them are compulsory of course
>>>- In the host template (will then only overwrite what's not in host
>>>definition)
>>> Same syntax
>>>- In the nagios.cfg file :=20
>>> snmp_login=3D1,,/
>>> snmp_login=3D3,,,/
>>>=09
>>> This is generic snmp login for networks : it will be=20
>>put in the host
>>>snmp info if the host hasn't got any, and if it's address=20
>>ma
...[email truncated]...
