Re: [Nagios-devel] bug: unlocking an invalid mutex
On Thu, Oct 18, 2007 at 12:14:10PM -0500, Ethan Galstad wrote:
> Did you by chance have external commands disabled when you got the SIGABRT?
> I believe the problem was due to the external_command_buffer.buffer_lock
> mutex being accessed even in external commands were disabled (in which
> case the mutex wouldn't exist).
It aborts both with and without external commands enabled (if you mean the
check_external_commands flag).
> A fix has been committed to CVS (both the 2.x and HEAD branches). When
> you get a chance, test the new 2.x CVS code and see if it solves the
> problem.
I applied xdata/xsddefault.c rev. 1.58 (or 1.30.2.4) but it doesn't fix the
problem.
Geert
