Marcel Mitsuto Fucatu Sugano wrote:
> Hi,
> Nagios 2.5, SuSE9.3.
> Syslog-ng 1.6.8.
> I am configuring some passive checks to be transported by syslog-ng. But
> keeping nsca daemon listening for other distributed agents check
> results. Syslog-ng is only transporting results that are generated by
> the monitored servers itself.
> So i've configured syslog-ng to write directly to nagios.cmd. Everything
> working fine, but as we are receiving check results from diferent
> distributed nagios servers, I wonder if whether or not msgs written at
> nagios.cmd has to be cronological. I mean, if some distributed server
> lost the synchronization with ntp, and the epoch time of one msg gets
> written to the nagios pipe with a timestamp lower than the one before
> that, will Nagios drop the delayed check result?
> Thanks for any comments on this matter.
> Marcel
IIRC Nagios shouldn't drop check results with out-of-order timestamps.
Hope that helps.
Ethan Galstad,
Nagios Developer
Email: [email protected]
