Re: [Nagios-devel] RFE for Nagios passive checks display
Hash: SHA1
On 19/01/09 06:00 PM, Thomas Guyot-Sionnest wrote:
> Oh you may be right then - I never used the defaults here. I used the
> following patch for quite some time now (In the 2.x series i was adding
> the unhandled stuff as it wasn't there yet),. It does the following things:
I forgot to mention, if you're applying the patch on an already
configured source tree, don't forget to re-run 'config.status' as it's
this command that rebuild the static HTML pages (config.status is
normally run automatically after the configure script finishes).
Than you can 'make install-html' (iirc) to replace the html pages with
the patched ones.
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFJdQ1M6dZ+Kt5BchYRAj7tAKC+clXEhBi3IPILrofgybhzYG/S/QCfVJ1v
dqgZwgwFOocbZvUmo9S8BuU=
=VQV4
-----END PGP SIGNATURE-----
