[Nagios-devel] Prototypes in utils.h
--------------080609010205030402090704
Content-Type: text/plain; charset=us-ascii; format=flowed
I've started auditing the plugins and I've got a couple of questions.
Function arguments are often named in the prototypes contained in
utils.h (but not always). Is there a reason for that? Portability
springs to mind, but utils.c makes heavy use of asprintf() which is a
GNU extension.
On a side-note, there's no prototype for usage4() in utils.h
The attached patch takes care of both issues.
OP5 AB www.op5.se
Lead Developer
name="nagiosplug-utils_prototypes.diff"
Content-Disposition: inline;
filename="nagiosplug-utils_prototypes.diff"
--- ../nagiosplug.orig/plugins/utils.h 2004-12-03 18:48:53.000000000 +0100
+++ plugins/utils.h 2004-12-04 16:40:13.000000000 +0100
@@ -16,9 +16,9 @@
/* $Id: utils.h,v 1.21 2004/12/03 17:48:53 opensides Exp $ */
void support (void);
-char *clean_revstring (const char *revstring);
+char *clean_revstring (const char *);
void print_revision (const char *, const char *);
-void die (int result, const char *fmt, ...) __attribute__((noreturn,format(printf, 2, 3)));
+void die (int, const char *, ...) __attribute__((noreturn,format(printf, 2, 3)));
/* Handle timeouts */
@@ -57,7 +57,7 @@
#endif
#ifndef HAVE_GETTIMEOFDAY
-int gettimeofday(struct timeval *tv, struct timezone *tz);
+int gettimeofday(struct timeval *, struct timezone *);
#endif
double delta_time (struct timeval tv);
@@ -65,46 +65,47 @@
/* Handle strings safely */
-void strip (char *buffer);
-char *strscpy (char *dest, const char *src);
-char *strnl (char *str);
-char *strpcpy (char *dest, const char *src, const char *str);
-char *strpcat (char *dest, const char *src, const char *str);
+void strip (char *);
+char *strscpy (char *, const char *);
+char *strnl (char *);
+char *strpcpy (char *, const char *, const char *);
+char *strpcat (char *, const char *, const char *);
int max_state (int a, int b);
-void usage (const char *msg) __attribute__((noreturn));
-void usage2(const char *msg, const char *arg) __attribute__((noreturn));
-void usage3(const char *msg, int arg) __attribute__((noreturn));
+void usage (const char *) __attribute__((noreturn));
+void usage2(const char *, const char *) __attribute__((noreturn));
+void usage3(const char *, int) __attribute__((noreturn));
+void usage4(const char *);
-const char *state_text (int result);
+const char *state_text (int);
#define max(a,b) (((a)>(b))?(a):(b))
#define min(a,b) (((a)<(b))?(a):(b))
-char *perfdata (const char *label,
- long int val,
- const char *uom,
- int warnp,
- long int warn,
- int critp,
- long int crit,
- int minp,
- long int minv,
- int maxp,
- long int maxv);
-char *fperfdata (const char *label,
- double val,
- const char *uom,
- int warnp,
- double warn,
- int critp,
- double crit,
- int minp,
- double minv,
- int maxp,
- double maxv);
+char *perfdata (const char *,
+ long int,
+ const char *,
+ int,
+ long int,
+ int,
+ long int,
+ int,
+ long int,
+ int,
+ long int);
+char *fperfdata (const char *,
+ double,
+ const char *,
+ int,
+ double,
+ int,
+ double,
+ int,
+ double,
+ int,
+ double);
/* The idea here is that, although not every plugin will use all of these,
most will or should. Therefore, for consistency, these very common
--------------080609010205030402090704--
