Re: [Nagios-devel] Patches for NDOUtils
On 21 Feb 2007, at 15:25, Ethan Galstad wrote:
> It shouldn't be too bad - if all goes well, the DB schema should
> stabilize fairly quickly.
Famous last words! Trust me, you will always find new things to
change (cf with Nagios configuration syntax).
BTW, good job on adding the host_object_id to the nagios_services
table - this speeded up some of our queries by a large magnitude
because we were avoiding joins across the nagios_objects table (where
the join by name was particularly slow).
Ton
http://www.altinity.com
T: +44 (0)870 787 9243
F: +44 (0)845 280 1725
Skype: tonvoon
