Hi!
I'm think there is a mistake at the "Inter-check delay" paragraph in the "Service check scheduling" part of the Nagios 1.0 Documentation
(http://nagios.sourceforge.net/docs/1_0/ ... heck_delay).
It says: "inter-check delay = (total normal check interval for all services) / (total number of services)", but the right equotations are:
average check interval = (total normal check interval for all services) / (total number of services)
inter-check delay = (average check interval) / (total number of services)
Another note: Should be noted at the "Statusmap CGI Background Image" paragraph in the "CGI Configuration File Options" part,
that this image only visible, if somebody use "User-supplied coords" as Layout Method.
Maybe these corrections can be applied to the ucoming 2.0 Documentation.
Bye, Tamas!
If this is not the correct list to post such things, please infrom me the correct way. Thanks.
