Re: [Nagios-devel] NDO Stops Nagios Service Checks
------_=_NextPart_001_01C9DF93.F0D03813
Content-Type: text/plain;
charset="us-ascii"
=20
mysql is busy with writing and updating because of the modiling of the
DB. Have a look at the patches for the modeling, located at the ndo
source code.
=20
Mit freundlichen Gruessen / With best regards
Daniel Bierstedt
Systems Administrator
C. Rob. Hammerstein GmbH & Co KG
Merscheider Str. 167
D-42699 Solingen
phone +49 212 3393 562
fax +49 212 3393 445
=20
mailto:[email protected] =20
http://www.crh-group.com =20
__________________________________________
This transmission is confidential and intended solely for the person or
organization to whom it is addressed. It may contain privileged and
confidential information. If you are not the intended recipient, you
should not copy, distribute or take any action in reliance on it.
If you have received this transmission in error, please notify the
sender at the e-mail address above.
=20
Von: [email protected]
[mailto:[email protected]]=20
Gesendet: Donnerstag, 28. Mai 2009 09:53
An: Nagios Developers List
Betreff: [Nagios-devel] NDO Stops Nagios Service Checks
I deployed and configured Nagios-3.0.6 and NDOutiles 1.4b7 for one
customer.=20
Nagios is Monitoring 200 networking devices and more then 1500 services.
For last three month its working fine. But Suddenly Nagios stops service
checks.=20
When i stops NDOutils nagios doing service checks, but when i start
NDOutils nagios stops service checks.
I enabled debug option in Nagios and NDOutils and set debug level -1,
but i did not able to identify what is the real problem? =20
Thanks & Regards
Mutharasu
MobileNo:9380121346
Content-Type: text/html;
charset="us-ascii"
mysql is busy with writing and updating because of the modiling =
of the=20
DB. Have a look at the patches for the modeling, located at the ndo =
source=20
code.
Mit freundlichen Gruessen / With best =
regardsDaniel=20
BierstedtSystems AdministratorC. Rob. Hammerstein GmbH =
& Co=20
KGMerscheider Str. 167D-42699 Solingenphone +49 212 =
3393=20
562fax   +49 212 3393=20
445           =
   mailto:[email protected]=
m           &n=
bsp;     http://www.crh-group.com__=
________________________________________This=20
transmission is confidential and intended solely for the person or =
organization=20
to whom it is addressed.  It may contain privileged and =
confidential=20
information. If you are not the intended recipient, you should not copy, =
distribute or take any action in reliance on it.If you have =
received=20
this transmission in error, please notify the sender at the e-mail =
address=20
above.
Von: =
Muthu
...[email truncated]...
