[Nagios-devel] Status Map
Nagios 2.5
Redhat EL4
I have set my default status map layout to User Supplied Coords.
If I go to my status map and change it to another value and click=
on update it displays the information in the requested format.
When the update interval has elapsed it then displays the staus=
map showing it in User Supplied Coords format.
Is this a bug?
Second thing
Extract from 2.5 documentation
The scripts should examine the values of the arguments passed in
and take any necessary action based upon those values. The best
way to understand how event handlers should work is to see and
example. Lucky for you, one is provided below. There are also some
sample event handler scripts included in the eventhandlers/ subdirectory
of the Nagios distribution. Some of these sample scripts demonstrate
the use of external commands to implement redundant monitoring
hosts.=20
After an installation from source an eventhandler subdirectory is=
not created, is there an additional make command to run to get=
this directory or does the documentation need to be corrected?
G
