[Nagios-devel] nrpe-2.4 still identifies itself as 2.3
------=_NextPart_000_0160_01C63C5D.D95A80D0
Content-Type: text/plain;
charset="us-ascii"
Hi Ethan,
you forgot to update the version in nrpe-2.4's configure, nrpe.spec,....
so if you call it as nrpe -v it still says
Version: 2.3
Last Modified: 01-23-2006
I attach a patch which sets version to 2.4 and release date to 2006-02-22.
greetings from munich,
Gerhard
Content-Type: application/octet-stream;
name="nrpe-2.4-version2.4.patch"
filename="nrpe-2.4-version2.4.patch"
diff -Naur nrpe-2.4/configure nrpe-2.4-version2.4/configure=0A=
--- nrpe-2.4/configure 2006-02-23 00:51:57.000000000 +0100=0A=
+++ nrpe-2.4-version2.4/configure 2006-02-28 11:45:39.702901200 +0100=0A=
@@ -1294,9 +1294,9 @@=0A=
=0A=
=0A=
PKG_NAME=3Dnrpe=0A=
-PKG_VERSION=3D"2.3"=0A=
+PKG_VERSION=3D"2.4"=0A=
PKG_HOME_URL=3D"http://www.nagios.org/"=0A=
-PKG_REL_DATE=3D"01-23-2006"=0A=
+PKG_REL_DATE=3D"02-22-2006"=0A=
=0A=
ac_aux_dir=3D=0A=
for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do=0A=
diff -Naur nrpe-2.4/configure.in nrpe-2.4-version2.4/configure.in=0A=
--- nrpe-2.4/configure.in 2006-02-23 00:51:57.000000000 +0100=0A=
+++ nrpe-2.4-version2.4/configure.in 2006-02-28 11:46:00.155633500 +0100=0A=
@@ -9,9 +9,9 @@=0A=
AC_PREFIX_DEFAULT(/usr/local/nagios)=0A=
=0A=
PKG_NAME=3Dnrpe=0A=
=0A=
dnl Figure out how to invoke "install" and what install options to use.=0A=
AC_PROG_INSTALL=0A=
diff -Naur nrpe-2.4/include/common.h nrpe-2.4-version2.4/include/common.h=0A=
--- nrpe-2.4/include/common.h 2006-01-23 17:36:50.000000000 +0100=0A=
+++ nrpe-2.4-version2.4/include/common.h 2006-02-28 11:46:20.998983300 =
+0100=0A=
@@ -23,8 +23,8 @@=0A=
=0A=
#include "config.h"=0A=
=0A=
-#define PROGRAM_VERSION "2.3"=0A=
-#define MODIFICATION_DATE "01-23-2006"=0A=
+#define PROGRAM_VERSION "2.4"=0A=
+#define MODIFICATION_DATE "02-22-2006"=0A=
=0A=
#define OK 0=0A=
#define ERROR -1=0A=
diff -Naur nrpe-2.4/nrpe.spec nrpe-2.4-version2.4/nrpe.spec=0A=
--- nrpe-2.4/nrpe.spec 2006-01-23 17:36:50.000000000 +0100=0A=
+++ nrpe-2.4-version2.4/nrpe.spec 2006-02-28 11:46:32.608135400 +0100=0A=
@@ -1,5 +1,5 @@=0A=
%define name nrpe=0A=
-%define version 2.3=0A=
+%define version 2.4=0A=
%define release 1=0A=
%define nsusr nagios=0A=
%define nsgrp nagios=0A=
------=_NextPart_000_0160_01C63C5D.D95A80D0--
