Show the .cvsignore files some love
--------------010603070505000801050600
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
This speeds up and unclutters output quite a lot when
working with the repo in git. I should think it helps
a bit when working in CVS too.
Either way, it's always prudent to let the SCM ignore
build-products. This patch does just that.
Note that I'm deliberately choosing to not ignore
include/{Makefile,nagios.h}, as I expect them to be
tracked rather than generated once my that patch
hits the upstream repo (nudge, nudge ;-)
Signed-off-by: Andreas Ericsson
Also attached, for application convenience.
.cvsignore | 4 ++++
base/.cvsignore | 4 ++++
cgi/.cvsignore | 1 +
common/.cvsignore | 1 +
contrib/.cvsignore | 1 +
html/.cvsignore | 3 +++
include/.cvsignore | 4 ++++
module/.cvsignore | 1 +
sample-config/.cvsignore | 2 ++
xdata/.cvsignore | 2 ++
10 files changed, 23 insertions(+), 0 deletions(-)
create mode 100644 base/.cvsignore
create mode 100644 common/.cvsignore
create mode 100644 html/.cvsignore
create mode 100644 include/.cvsignore
create mode 100644 module/.cvsignore
create mode 100644 sample-config/.cvsignore
create mode 100644 xdata/.cvsignore
diff --git a/.cvsignore b/.cvsignore
index d5128cc..f3064d6 100644
--- a/.cvsignore
+++ b/.cvsignore
@@ -5,3 +5,7 @@ Prototype
nagios.SPARC.pkg.tar.gz
autom4te.cache
+config.log
+config.status
+daemon-init
+/Makefile
diff --git a/base/.cvsignore b/base/.cvsignore
new file mode 100644
index 0000000..eeeb7ba
--- /dev/null
+++ b/base/.cvsignore
@@ -0,0 +1,4 @@
+*.o
+Makefile
+nagios
+nagiostats
diff --git a/cgi/.cvsignore b/cgi/.cvsignore
index b94020f..46c15cc 100644
--- a/cgi/.cvsignore
+++ b/cgi/.cvsignore
@@ -1,2 +1,3 @@
+*.o
*.cgi
Makefile
diff --git a/common/.cvsignore b/common/.cvsignore
index 0000000..f3c7a7c
--- /dev/null
+++ b/common/.cvsignore
@@ -0,0 +1 @@
+Makefile
diff --git a/contrib/.cvsignore b/contrib/.cvsignore
index c933d02..4f1e93a 100644
--- a/contrib/.cvsignore
+++ b/contrib/.cvsignore
@@ -1 +1,2 @@
perlxsi.c
+Makefile
diff --git a/html/.cvsignore b/html/.cvsignore
index 0000000..1822566
--- /dev/null
+++ b/html/.cvsignore
@@ -0,0 +1,3 @@
+Makefile
+index.html
+side.html
diff --git a/include/.cvsignore b/include/.cvsignore
index 0000000..8cf3415
--- /dev/null
+++ b/include/.cvsignore
@@ -0,0 +1,4 @@
+locations.h
+config.h
+snprintf.h
+cgiutils.h
diff --git a/module/.cvsignore b/module/.cvsignore
--- /dev/null
+++ b/module/.cvsignore
@@ -0,0 +1 @@
+Makefile
diff --git a/sample-config/.cvsignore b/sample-config/.cvsignore
index 0000000..32d26a5
--- /dev/null
+++ b/sample-config/.cvsignore
@@ -0,0 +1,2 @@
+*.cfg
+httpd.conf
diff --git a/xdata/.cvsignore b/xdata/.cvsignore
index 0000000..cc00087
--- /dev/null
+++ b/xdata/.cvsignore
@@ -0,0 +1,2 @@
+Makefile
+*.o
git-1.5.3.4.1207.g6d77b
OP5 AB www.op5.se
Content-Type: text/x-patch;
name="0001-Show-the-.cvsignore-files-some-love.patch"
Content-Disposition: inline;
filename="0001-Show-the-.cvsignore-files-some-love.patch"
From cb84c05fa820e89c11b599ca8a4f0f9ed321e153 Mon Sep 17 00:00:00 2001
Date: Tue, 16 Oct 2007 20:59:49 +0200
Subject: Show the .cvsignore files some love
tracked ra
...[email truncated]...
