I am new to Nagios and am having difficulty getting a remote host to display in the web interface. The local host and preconfigured services display just fine. My monitoring server is running Open SUSE 11.3 with Nagios installed from the distribution media and the machine is patched current. The remote host is also an Open SUSE 11.3 machine with NRPE and NRPE Plug-ins installed.
I follwoed the manuals for installing NAgios and NRPE and the manual checks run fine. The check of configuration for Nagios yields this output:
# nagios -v ../nagios.cfg
Nagios Core 3.2.1
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 03-09-2010
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config file '/etc/nagios/objects/commands.cfg'...
Processing object config file '/etc/nagios/objects/contacts.cfg'...
Processing object config file '/etc/nagios/objects/timeperiods.cfg'...
Processing object config file '/etc/nagios/objects/templates.cfg'...
Processing object config file '/etc/nagios/objects/localhost.cfg'...
Checking services...
Checked 8 services.
Checking hosts...
Checked 1 hosts.
Checking host groups...
Checked 1 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 1 contacts.
Checking contact groups...
Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 25 commands.
Checking time periods...
Checked 5 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
A manual check of the remote host yields this output:
# /usr/lib/nagios/plugins/check_nrpe -H target -c check_users
USERS OK - 3 users currently logged in |users=3;5;10;0
Commands.cfg was modified thusly:
# 'check_nrpe' command definition
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
I created a template file for monitoring Linux hosts using the pattern in templates.cfg Its contents are:
name linux-template ; The name of this host template
use generic-host ; This template inherits other values from the generic-host template
check_period 24x7 ; By default, Linux hosts are checked round the clock
check_interval 5 ; Actively check the host every 5 minutes
retry_interval 1 ; Schedule host check retries at 1 minute intervals
max_check_attempts 10 ; Check each Linux host 10 times (max)
check_command check-host-alive ; Default command to check Linux hosts
notification_period 24x7 ; Linux admins hate to be woken up, so we only notify during the day
; Note that the notification_period variable is being overridden from
; the value that is inherited from the generic-host template!
notification_interval 120 ; Resend notifications every 2 hours
notification_options d,u,r ; Only send notifications for specific host states
contact_groups admins ; Notifications get sent to the admins by default
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE!
I also created a cfg file for the remote host named target. (Not original but functional anyway.)
# Define monitored host
use linux-template ;Inherit default valuses from Linux template
host_name target ;Server to be monitored
alias target
address 10.1.10.10
register 1
# Define services to be monitored
# CPU Load service definition
use generic-service ;Service provided as part of nrpe.cfg
host_name target
service_description CPU Load
check_command check_nrpe!check_load
# Current Users service definitions
host_name target
service_descriptiom Current Users
check_command check_nrpe!check_users
# Total Processes service definitions
host_name target
service_descriptiom Total Processes
check_command check_nrpe!check_total_procs
Any help would be appreciated.
Remote Host Does Not Appear in Web Interface
tcicirello
Re: Remote Host Does Not Appear in Web Interface
Nagios needs to be restarted anytime you want to change the configuration. Did you restart the nagios daemon after verifying?
tcicirello
Yes, I did. I found that I hadn't added the new config files to nagios.cfg and that fixed the problem. Thanks.
Good deal. You can also include directories instead of individual files, and I would recommend creating a "hosts" and a "services" directory for all of your new configs, and then including those directories in the main nagios.cfg. That way you don't have to manually add each file every time you add a new host or service.
