Andreas Ericsson wrote:
> Hendrik Bäcker wrote:
>> Hi List,
>> after a four days running nagios 3 (latest cvs) I've recognized that my
>> system has only 80 MByte of free Memory (top).
>> After stopping Nagios the amount of free memory jumps up to 2,7 GByte.
> Are you using embedded perl? It's the single largest memory-sink in Nagios
> at the moment.
>> Now my question: What is the best way to find such a leak (if there is one)?
> Ues valgrind.
>> I know tools like valgrind, but I am not familar with right use of it.
>> So, if someone can hit me to the right direction, I will try to debug.
> man valgrind, or learn how to implement ref-counting in C and add it to
> Nagios. If done properly, it will eliminate all in-core leaks and leave
> only the embedded perl ones.
I'm guessing the mem leak is somewhere in the newly rewritten macro
code. Here's what I do to run valgrind...
Edit base/Makefile and uncomment the "CFLAGS" line below...
# Compiler flags for use with Valgrind
#CFLAGS=-O0 -g -DHAVE_CONFIG_H @GLIB_INCLUDE@ -DNSCORE
This will override the normal flags used to compile the Nagios daemon.
Recompile the Nagios daemon:
cd base
make clean
make
NOTE: If the large_installation_tweaks option is enabled, you will get a
lot of errors, because Nagios intentionally does not free memory in
child processes - it leaves that up to the kernel. I would recomment
running Nagios with this option disabled in order to track down memory
leaks.
Run valgrind like so - debug files will be written to
/tmp/valgrind.[pid] for inspection.
valgrind --log-file=/tmp/valgrind --trace-children=no --leak-check=full
nagios /usr/local/nagios/etc/nagios.cfg
I just ran this myself and noticed several mem leaks from the new macro
code. Damn, I thought I ran valgrind before committing the changes.
Heading out of town today, but I'll get some patches into CVS when I get
back in a few days.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
