Shad L. Lords wrote:
> I tried the latest CVS yesterday and started a strace from the very
> beginning. It took less then 5 hours for it to stop processing checks.
> I've uploaded the compressed strace for anyone that is interested. It is
> about 5Mb in size. You might be able to get more information out of it if
> you can see what leads up to the issue.
The first ENOMEM appears 13:32:39. The first fd leak seems to appear 13:32:41.
It seems my first conclusion was in error. The ENOMEM's aren't the result of
fd leaks; It's the other way around. Or rather, they're separate bugs, but
Nagios does something wrong in the ENOMEM path of fork().
Valgrind should be able to give a few hints. If you've got time to run Nagios
under it on your system, it would most likely be very valuable.
OP5 AB www.op5.se
