[Nagios-devel] Antw: Re: Missing group in Makefile
Thanks alot. The patches worked like a charm.
>>> [email protected] 06/14/07 8:31 >>>
Looks like this is still a problem in CVS. Attached is the patch for the
configure script
On 6/13/07, Sascha A. M=FCller wrote:
> Hi list,
> this is my first contribution so please inform me of any
> rules/speficitation I might violate.
> I encountered an inconsistency while trying to install nrpe-2.8.1.
> I configured with the option --nagios-group=3Dnagios. While configure =
runs
> fine it does not state the group at the final configure options that are
> shown when configure is done.
> The group name shows up emtpy.
> Also make runs fine with missing group the command make install-plugins
> stops with an error. This is due to the group not been set and so the =
syntax
> does not come out right.
> Editing the Makefile in the src/ directory and entering the right
> groupname in line 27 before the make solves the problem.
> Just a minor thing, but might prevent some less experienced user from
> using nrpe.
> Hope this is not the second time this error is reported.
> Regards Sascha M=FCller
> This SF.net email is sponsored by DB2 Express
> Download DB2 Express C - the FREE version of DB2 express and take
> control of your XML. No limits. Just data. Click to get it now.
> http://sourceforge.net/powerbar/db2/=20
> Nagios-devel mailing list
> [email protected]=20
> https://lists.sourceforge.net/lists/lis ... s-devel=20
