Good day,
I checked out a CVS copy of Nagios this morning and tried to compile in
MySQL support via the .spec file. However, the install fails.
The install terminates with:
Processing files: nagios-devel-1.0b1-1ignus2
Finding Provides: (using /usr/lib/rpm/find-provides)...
Finding Requires: (using /usr/lib/rpm/find-requires)...
File not found: /var/tmp/nagios-buildroot/usr/sbin/nagios
PreReq: rpmlib(PayloadFilesHavePrefix) <= 4.0-1 rpmlib(CompressedFileNames)
<= 3.0.4-1
Requires(rpmlib): rpmlib(PayloadFilesHavePrefix) <= 4.0-1
rpmlib(CompressedFileNames) <= 3.0.4-1
RPM build errors:
Scrolling a little ways up reveals the following error:
make[1]: Entering directory `/usr/src/redhat/BUILD/nagios-1.0b1/base'
strip nagios
/usr/bin/install -c -m 775 -d /var/tmp/nagios-buildroot/usr/sbin
/usr/bin/install: `/var/tmp/nagios-buildroot/usr/sbin' exists but is not a
directory
make[1]: *** [install] Error 1
I'm guessing that this is a bug related either to the MySQL support or a
recent bug with CVS, as my compile earlier this week (without MySQL support)
worked fine.
Thanks in advance,
Darren Gamble
Planner, Regional Services
Shaw Cablesystems GP
630 - 3rd Avenue SW
Calgary, Alberta, Canada
T2P 4L4
(403) 781-4948
