Horvath Tamas wrote:
> Hi List!
> I use Nagios 1.2 and noticed that when I would like to delete a scheduled
> downtime (via click to the trash icon under Action column on page Downtime)
> there is "Scheduled Downtime ID:" row under "Command Options" table. It is
> filled in automatically by Nagios, so I always delete that item which I
> wanted.
> BUT I CAN'T KNOW WHICH ID BELONGS TO WHICH SCHEDULED DOWNTIME!!!
Don't you know which one you clicked??
> In contrast to this: THERE IS A "Comment ID" COLUMN ON THE "Comments" PAGE.
> May I suggest to improve the extinfo.cgi to display this "Comment ID" column
> on the Downtime page?
You can ofcourse suggest whatever you want. I'll gladly ignore it
though, as I'm sure pretty much everybody else will.
May I suggest you submit a patch instead? I don't think such a change
would be very gratefully received though, since it means parsing the
comments file before letting the user make his/her choice, which means
the cgi's will be even slower than they presently are.
> Thanks in advance.
You're welcome.
OP5 AB www.op5.se
Lead Developer
