Re: [Nagios-devel] first_notification_delay & recovery messages
Brandino Andreas wrote:
> Hi all again!!
> I face a problem with first_notification_delay (I wrote a similar
> mail some days ago but still i cant find any mistake in my
> configuration)
> - When i use "first_notification_delay 10" when i should get a recovery
> notification? Immediately after the service state is "OK" or service
> state is OK + notification interval?
> - If i remove the option "first_notification_delay 10" i get
> with success recovery messages.
> When i use "first_notification_delay 10" nagios never calls the
> notification command (doesn't appear an attempt to the notification
> log). So it isn't an error in my notification command.
> All the configuration files where old, from version 2.5x. Today i
> installed again 3.03b from scratch , and i migrate all configuration
> (using the new default files),line by line , so i don't miss anything new.
> But again i don't get any recovery notifications.
> A service configuration looks like that:
> define service{
> name local-service ; The name of this service template
> use generic-service ; Inherit default values from the generic-service definition
> max_check_attempts 4 ; Re-check the service up to 4 times in order to determine its final (hard) state
> normal_check_interval 5 ; Check the service every 5 minutes under normal conditions
> retry_check_interval 1 ; Re-check the service every minute until a hard state can be determined
> register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
> define service{
> use generic-service ; Name of service template to use
> host_name Central
> service_description Service1
> is_volatile 0
> check_period 24x7
> max_check_attempts 3
> contact_groups sadmins
> notification_interval 0
> notification_period 24x7
> notification_options c,r
> check_command check_snmp_interface!snmp!service1
> Any idea?
> Regards
Is the service problem getting resolved before 1) the 10 second
notification delay and 2) the next active check of the service? If so,
there would be no problem notification in the first place, so you
wouldn't get a recovery notification. Recovery notifications only go
out if Nagios sent a notification about a problem.
Ethan Galstad,
Nagios Developer
Email: [email protected]
