First time trying to work with plugins - no luck
mocjack
Post by mocjack »
I am running Nagios XI under CentOS 64bit. Everything works perfectly right now, but I have started to play with the plugins for Cisco available on the nagios exchange.
Here is my issue...
I downloaded the cisco check for check_catalyst_load ( http://exchange.nagios.org/directory/Pl ... ad/details ).
Configured everything (I thought) properly.. uploaded the plugin through the web interface, verified root could run the plugin by doing it from command shell... When I run it from the command shell it returns an "OK!" with the load of the switch listed (20, 20, 20).
When I run it in Nagios, I get a result of "NULL".
Here is how I have it set up:
Can anyone see anything here I have done wrong? I have tried all sorts of combinations but I cannot get it to work. As I said, it works from command-line logged in as the root (nagios) account, so I know I have the community string and such correct.
Thanks to anyone in advance!!!!!
-Jack
rdedon
Re: First time trying to work with plugins - no luck
Post by rdedon »
Hello Jack,
could you show the exact command and output (barring any sensitive information) so that we may better troubleshoot please?
Thanks!
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
