Stash next pointer for entry when iterating over a linked list in the obiously
correct fanout lib.
The next pointer is lost when freeing the entry item in a for loop... One
penny^Cpointer saved is a pointer earned, as my grandma used to say...
Signed-off-by: Max Sikström
lib/fanout.c | 10 +++++++---
1 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/lib/fanout.c b/lib/fanout.c
index dda2874..a14d693 100644
--- a/lib/fanout.c
+++ b/lib/fanout.c
@@ -29,13 +29,15 @@ fanout_table *fanout_create(unsigned long size)
void fanout_destroy(fanout_table *t, void (*destructor)(void *))
unsigned long i;
+ struct fanout_entry *next;
if (!t || !t->entries || !t->alloc)
return;
for (i = 0; i alloc; i++) {
struct fanout_entry *entry;
- for (entry = t->entries; entry; entry = entry->next) {
+ for (entry = t->entries; entry; entry = next) {
+ next = entry->next; /* Stash it, it might be gone later */
if (destructor) {
destructor(entry->data);
@@ -67,13 +69,15 @@ int fanout_add(struct fanout_table *t, unsigned long key, void *data)
void *fanout_remove(fanout_table *t, unsigned long key)
- struct fanout_entry *entry, *prev = NULL;
+ struct fanout_entry *entry, *next, *prev = NULL;
unsigned long slot;
return NULL;
slot = key % t->alloc;
- for (entry = t->entries[slot]; entry; prev = entry, entry = entry->next) {
+ for (entry = t->entries[slot]; entry; prev = entry, entry = next) {
if (entry->key == key) {
void *data = entry->data;
if (prev) {
1.7.1
