multiple escalation in hostgroup
edpbej
Post by edpbej »
I want to try to do a multiple escalation in a hostgroup.
the host is configured that every 30 min. send a mail notification is the host is down .
I do a hostescalation that send a sms if is the second notification.
define hostescalation{
hostgroup_name eoc-W2K8R2-64bit
contact_groups provaescalation,eoc-admin-group
first_notification 2
last_notification 2
notification_interval 0
escalation_period weekescalation
I want that the normal e-mail notification is send continuosly, is possible? How?
I'm sorry for my english.
Best regards
Jonathan
rdedon
Re: multiple escalation in hostgroup
Post by rdedon »
Hello Jonathan,
could you please give us a few more details so that we may better assist you:
1. Linux Distribution and version?
2. 32 or 64bit?
3. VMware Image or Manual Install of XI?
4. Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL?
5. Is this Nagios Core or Nagios XI?
Thank you.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
edpbej
Post by edpbej »
the linux distribution is a RHEL 5 64bit with Nagios Core manualy installed, there are not special configurations.
my problem is that I have the escalation but I want that also the normal notification (every 30min if is a problem) go.
Jonathan
mguthrie
Post by mguthrie »
Take a look at this doc from Nagios Core, this might have what you need:
http://nagios.sourceforge.net/docs/3_0/escalations.html
