Re: [Nagios-devel] Nagios ePN and perl modules
On Thu, 2 May 2002, Douglas E. Warner wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> I tracked down the problem. It was caused by the check_ntp script after I put
> in the
> use lib utils.pm;
> like you suggested. So far the only thing that has worked for me is to hard
> code the path into it. Maybe this will just get changed when a user compiles
> the nagios-plugins?
> - -Doug
As I said, "use lib utils.pm" will cause perl to generate errors. But the
compile process takes care of that...
Try running "gawk -f subst check_ntp.pl > test.pl" where subst created
from subst.in from the version from nagiosplug cvs..
-sg
