Re: [Nagios-devel] ndoutils and historical performance data
I'd be happy to incorporate a patch to provide parsed perfdata in the
ndoutils db if someone wants to take a stab at it. I think the raw
perfdata field should remain and data that can be parsed should be
stored elsewhere. That way data doesn't disappear just because it
doesn't conform to the official perfdata standards.
mike conigliaro wrote:
> hey flo,
> i dont agree that mysql storage is not needed. i chose perfparse specifically
> for this feature, so it would be nice if this was still an option. at my
> company, its important that our customers have access to performance data so
> they can generate their own reports and see the current status of their servers.
> since we dont want our customers accessing our nagios server directly, we
> created our own read-only nagios web interface (on a different, publicly
> accessible server) using the ndoutils and perfparse databases as a data source.
> i dont have a lot of experience with rrdtool, but if performance data was only
> stored in rrd files on the nagios box, it seems like there would be no easy way
> to retrieve the data from elsewhere on the network. my first thought is that id
> have to implement a clustered filesystem or some sort of rsync process in order
> to share the rrd files, and thats a bit more complicated than writing a few sql
> queries. =)
> it seems to me that if ndoutils took care of the parsing/storage on its own, the
> only thing needed from the perfparse project would be the report generation
> framework. and then id begin to wonder if perfparse was even appropriate as a
> separate project, since this is something that should be (and could very easily
> be) incorporated into the new nagios web interface. imho, graphs are
> important/useful enough that they should be a core feature in any a monitoring
> application.
> just my 2 cents.
> Mike Conigliaro
> ProActive Technologies
> [email protected]
> 203.239.0440 ext:317
> www.getproactivenow.com
> Florian Gleixner wrote:
>> Christoph Maser wrote:
>>>> http://nagiosplug.sourceforge.net/devel ... tml#AEN202
>>> Yes i know i was refereing to that. But since there is no mechanism in
>>> place to ensure the policy you will always find plugins wich will not
>>> follow the policy
>> Data that do not follow this guide can safely be discarded.
>>>> im also not sure why code would be needed from the perfparse project.
>>> I thought the parser might be not so simple and therefore reusing
>>> working code would be useful.
>> The parser is not the problem. A efficient and fast storage (database
>> design) and usable report generation (web interface) is more work. And
>> many people happy with rrd graphs, so no mysql storage would be needed.
>> Flo
Ethan Galstad,
Nagios Developer
Email: [email protected]
