Unable to create new groups or servers in Nagios XI
stkol76
Post by stkol76 »
Hi
We are evaluating Nagios XI at the moment and uptil now it have been running 100%.. But now when we try to create eigther a new machine from Wizard, or a new Service Group or Host Group, or even when applying the existing configuration. This has never been a problem before, since we have added multiple servers and groups without problem!
The error we get is:
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
We are running Nagios XI from the supplied VMware image supplied by Nagios, on our vSphere.
We have tried several times to reboot, but without any change!
I have attached the snapshot of the last error that was processed
I hope someone can help really fast, I would really appreciate that :-)
/Stig :-)
rdedon
Re: Unable to create new groups or servers in Nagios XI
Post by rdedon »
we will take a look at the attachment you provided and see if we can find any issues with what may be going on. Feel free to add any more information you may find relevant in the meantime while we are reviewing this.
Thank you,
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
rdedon
Post by rdedon »
Could you send the text file as well as this will help us isolate the issue?
Thanks!
Rene deDon
Technical Team
___
