Re: [Nagios-devel] Strange service scheduling
> Hi,
> Yes I have the same problem with this patch. For me the problem is only
> for
> services with timeperiods like this :
> define timeperiod{
> timeperiod_name mytimeperiod
> alias a simple timeperiod definition
> monday 07:30-12:00
> Julien Mathis, CTO
> www.merethis.com
> Mobile : +33(0)6.85.43.88.38
> Bureau : +33(0)1.78.12.00.23
> On Mon, Mar 2, 2009 at 4:59 PM, Ricardo Maraschini [email protected]> wrote:
> > Hi,
> > ----- "Ricardo Maraschini"
> > escreveu:
> > > Hello,
> > > We had a strange behaviour with a service schedule last night; The
> > > service was scheduled to be checked only on February/2010(Fri Feb 26
> > > 00:08:36 2010). This is very strange, looking to the code we found the
> > > following piece:
> > > base/checks.c:
> > > /* the service could not be rescheduled properly - set the next check
> > > time for next year, but don't actually reschedule it */
> > > if(time_is_valid==FALSE && next_valid_time==preferred_time){
> > Is there any problem with following patch?
> > http://article.gmane.org/gmane.network. ... =next+year
> > Awaiting.
> > -rm
did you experience this strange re-scheduling after manually applying my patch? The patch you've mentioned isn't applied in the official source code, see (revision 1.167)
http://nagios.cvs.sourceforge.net/viewv ... rkup#l_282
There is still the line 285
svc->next_check=(time_t)(next_valid_time+(60*60*24*365));
Please try my patch and check if the services are re-scheduled properly then. If the re-scheduling isn't working correctly though you're running Nagios with this patch, please tell me too.
Thanks.
Regards
Bernd
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
