Re: [Nagios-devel] [patch] Parent checking fails with
--------------010609080708020102070203
Content-Type: text/plain; charset=UTF-8; format=flowed
On 04/26/2011 10:44 AM, Andreas Ericsson wrote:
> On 04/26/2011 03:52 PM, Andrew Norris wrote:
>> In nagios 3.2.3 parent checks are not properly handled when
>> max_check_attempts is set to 1. run_sync_host_check_3x properly
>> executes the host check if not using cached data, but it never sets
>> check_result_code. This one-liner fixes that.
>> I didn't delve too deep, but I think the patch is correct. We have had
>> this running in production for a couple weeks now and it's saved us from
>> a deluge of notifications.
> I think you forgot to attach (or inline) the patch.
Naturally...
name="nagios-3.2.3-fix-hostcheck.patch"
filename="nagios-3.2.3-fix-hostcheck.patch"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--------------010609080708020102070203--
